simbata11 | Дата: Събота, 18.03.2017, 22:41:27 | Message # 1 |
Съобщения: 178
| Продавам си музиката от прелюда. Стъпало 130 лева.Бас каса 220 лева. Информация за стъпалото ---Pioneer GM-5100T 2-Channel Bridgeable Amplifier Перфектно състояние
Give into your deepest desire for power. Work it out how you want with the bridgeable amps. Drive 2 speaker channels or multiple subwoofer leads. Just consider the consequences whatever you do: pure and clean, distortion-free power. They ignite your system, but keep the heat under wraps. Techno wonders, these amps will rumble you to the core. Specifications Key features GM-5100T Bridgeable 2-channel capability 2 x 250 W or 1 x 760 W (Max. Power) Continuous output power: 2 x 125 W or 1 x 380 W (4 Ω) 2 x 190 W (2 Ω) 2 x 175 W or 1 x 520 W (4 Ω) DIN Power (DIN 45324, +B = 14.4 V) Load impedance capability (2 — 8 Ω) LPF: 80 Hz, -12 dB/Oct High Voltage Input capability (200 mV — 6.5 V) Features GM-5100T Type Bridgeable Power Amplifier PWM regulated MOSFET power supply Yes Channels 2 Load impedance capability 2 - 8 Ohm Bass Boost 50 Hz 0/6/12 dB RCA input terminals Yes Speaker Terminals Screw-type Power / ground terminals Large screw-type LPF 80 Hz High voltage input capability 200 mV - 6.5 V High performance balanced isolator circuit Yes Speaker line input Yes Specifications GM-5100T Maximum Output Power 2 x 250 Watt or 1 x 760 Watt (4 ohms) DIN power output (W) (DIN45324, +B = 14.4V) 2 x 175 W or 1 x 520 W (4 ohms) Continuous power output (RMS) 2 x 125 Watt or 1 x 380 (14.4V (20-20kHz/4ohms)) 2 x 190 (14.4V (20-20kHz/2ohms)) Frequency response 10 Hz - 50.000 Hz Distortion 0,015 % S/N ratio > 95 dB High Voltage Input Capability 200 mV - 6.5 V Max. current consumption (A/4ohms) 30 A Chassis size (W x H x D) 300 x 60 x 327 mm Unit weight 4.7 kg Баса е от серия на Pioneer която се използва за състезания. $IMAGE2$ $IMAGE3$ $IMAGE4$ $IMAGE5$ $IMAGE6$ $IMAGE7$ $IMAGE8$
simbata11 | Дата: Събота, 18.03.2017, 22:43:54 | Message # 2 |
Съобщения: 178
| https://bazar.bg/%D0%BE%....t-760w. https://bazar.bg/%D0%BE%....r-1500w
simbata11 | Дата: Вторник, 28.03.2017, 09:43:24 | Message # 3 |
Съобщения: 178
| Стъпалото е продадено
simbata11 | Дата: Петък, 02.06.2017, 13:46:54 | Message # 4 |
Съобщения: 178
| Малко информация за баса Pioneer TS-W101SPL .TS-W101 SPEC: A big fan of SPL? Then the TS-W101SPL may be your winning ticket. The high SPL capability — up to 165 dB — will charge your system with intense power and maximum force. Power output checks in at a heady 1500 W. Based on the same technology found in the TS-W5000SPL competition model, this subwoofer is filled with quality material including a wide-roll, 3-layer fibre woven radial surround. Get ready to rock the block! Specifications Key features TS-W101SPL Interlaced Glass Fibre/Carbon Fibre Reinforced IMPP cone Wide-roll, 3-layer fibre woven radial surround Double-stacked high power magnets Silver binding post terminal Aluminium die-cast basket with bottom hold structure Extended and vented pole yoke Dual 4 ohm voice coils (2 or 8 ohm) Optional accessories: - UD-G255 spoke grille - UD-W250S custom enclosure box Enclosure use Features TS-W101SPL Frequency response 18 - 2.500 Hz Sensitivity (1W/1m) 87 dB Recommended sealed enclosure (Litres) 28.3 Lowest resonance frequency (FS) 37 Hz Maximum Power 1.500 W Nominal input power 600 W Woofer size (cm) 25 cm Dual 4-ohm voice coils: 2 or 8 ohm yes
simbata11 | Дата: Неделя, 19.11.2017, 21:33:06 | Message # 5 |
Съобщения: 178
Sa6koOy | Дата: Понеделник, 25.12.2017, 12:05:29 | Message # 6 |
| Дай снимки на лично за всичките неща....
simbata11 | Дата: Петък, 09.03.2018, 15:20:13 | Message # 7 |
Съобщения: 178
| Баскасата е продадена.Темата е за ключ
