| ggushterov | Дата: Събота, 23.11.2013, 07:04:29 | Message # 1 |
 | Blocks   H22A4 Block = Open Deck   H22A block = Closed Deck   H23A block = Open Deck   H23A1 block = Closed Deck   F22 block = Open Deck   F23 block = Open Deck   F20B block = Open Deck
   Deck Height   H22A4 Block = 8.643   H22A block = 8.643   H23A block = 8.643   H23A1 block = 8.643   F22 block = 8.643   F23 block = 8.643   F20B block = 8.643
   Bore   H22A4 Block = 87mm/3.425   H22A block = 87mm/3.425   H23A block = 87mm/3.425   H23A1 block = 87mm/3.425   F22 block = 85mm/3.346   F23 block = 86mm/3.385   F20B = 85mm/3.346
   Забележка:   Поради различните стандарти на буталата (А=3.425/87mm, B=3.435/87.25mm) реалният диаметър на цилиндъра може да варира.   Rods
   Length   H22A4 = 5.633   H22A = 5.633   H23A = 5.572   H23A1 = 5.572   F22 = 5.572   F23 = 5.551   F20B = 5.709
   Width   H22A4 = .935   H22A = .935   H23A = .935   H23A1 = .935   F22 = .935   F23 = .780   F20B = .935
   BE Bore   H22A4 = 2.008   H22A = 2.008   H23A = 2.008   H23A1 = 2.008   F22 = 2.008   F23 = 1.890   F20B = 1.890
   Pin Bore   H22A = 21.97-21.98mm/.8649-.8654   H22A1 = 21.97-21.98mm/.8649-.8654   H22A4 = 21.97-21.98mm/.8649-.8654   H23A = 21.97-21.98mm/.8649-.8654   H23A1 = 21.97-21.98mm/.8649-.8654   F20A = 21.97-21.98mm/.8649-.8654   F20B = 21.97-21.98mm/.8649-.8654   F22A = 21.97-21.98mm/.8649-.8654   F22B = 21.97-21.98mm/.8649-.8654   F22B1 = 21.97-21.98mm/.8649-.8654   F22B2 = 21.97-21.98mm/.8649-.8654   F23A = 21.97-21.98mm/.8649-.8654
   Pistons
   Bore   H22A4 = 87mm/3.425   H22A = 87mm/3.425   H23A = 87mm/3.425   H23A1 = 87mm/3.425   F22 = 85mm/3.346   F23 = 86mm/3.385   F20B = 85mm/3.346
   Забележка:   Реалният диаметър може да варира в зависимост от стандарта на буталото (А,В)
   Compression Height   H22A4 = 1.221   H22A = 1.221   H23A = 1.203   H23A1 = 1.203   F22A1 = 1.203   F22A4 = 1.203   F23A1 = 1.181   F20B = 1.221
   Dome Volume   H22A = -1.9 cc   H22A Type S = +4.2 cc   H22A1 = -1.8 cc   H22A4 = -1.8 cc   H23A = +4.3 cc   H23A1 = -9.9 cc   F20A = -4.7 cc   F20B = +8.0 cc   F22A = -14.5 cc   F22B = -11.2 cc   F22B1 = -14.5 cc   F22B2 = -14.5 cc   F23A = -18.0 cc
   Wrist Pin Diameter   H22A4 = .866   H22A = .866   H23A = .866   H23A1 = .866   F22 = .866   F23 = .866   F20B = .866
   Колянов вал
   Stroke   H22A4 = 90.7mm/3.570   H22A = 90.7mm/3.570   H23A = 95mm/3.740   H23A1 = 95mm/3.740   F22 = 95mm/3.740   F23 = 97mm/3.818   F20B = 88mm/3.464
   Main Journal Diameter   H22A4 = 55mm   H22A4 = 50mm (1997 Only)   H22A = 50mm   H23A = 55mm   H23A1 = 50mm   F22 = 50mm   F23 = 55mm   F20B = 55mm
   Rod Journal Diameter   H22A4 = 1.888   H22A = 1.888   H23A = 1.888   H23A1 = 1.888   F22 = 1.888   F23 = 1.771   F20B = 1.771
   Цилиндрови глави
   Combustion Chamber Volume   H22A4 = 53.8cc   H22A = 53.8cc   H23A = 53.8cc   H23A1 = 50cc   F22A1 = 50cc   F22A4 = 50cc   F23A1 = 50cc   F23A4 = 50cc   F23A5 = 50cc   F20B =
   Intake Valve Diameter   H22A4 = 35mm   H22A = 35mm   H23A = 35mm   H23A1 = 34mm   F22 = 34mm   F23 = 34mm   F20B = 34mm
   Exhaust Valve Diameter   H22A4 = 30mm   H22A = 30mm   H23A = 30mm   H23A1 = 29mm   F22 = 29mm   F23 = 29mm   F20B = 29mm
   Head Gaskets
   Bore   H22A4 = 88mm   H22A = 88mm   H23A = 88mm   H23A1 = 88mm   F22 = 86mm   F23 = 87mm   F20B = 86mm
   Thickness   H22A4 = .026   H22A = .026   H23A = .026   H23A1 = .026   F22 = .026   F23 = .026   F20B = .026
   Забележка:   Дебелината на гарнитурата е измерена след смачкване
   Bearings
   Main Bearing Thickness   Blue: 2.013 - 2.010mm / 0.0793 - 0.0791   Black: 2.010 - 2.007mm / 0.0791 - 0.0790   Brown: 2.007 - 2.004mm / 0.0790 - 0.0789   Green: 2.004 - 2.001mm / 0.0789 - 0.0788   Yellow: 2.001 - 1.998mm / 0.0788 - 0.0787   Pink: 1.998 - 1.995mm / 0.0787 - 0.0785   Red: 1.995 - 1.992mm / 0.0785 - 0.0783
   Rod Bearing Thickness   Blue: 1.510 - 1.507mm / 0.0594 - 0.0593   Black: 1.507 - 1.504mm / 0.0593 - 0.0592   Brown: 1.504 - 1.501mm / 0.0592 - 0.0591   Green: 1.501 - 1.498mm / 0.0591 - 0.0590   Yellow: 1.498 - 1.495mm / 0.0590 - 0.0589   Pink: 1.495 - 1.492mm / 0.0589 - 0.0587   Red: 1.492 - 1.489mm / 0.0587 - 0.0586
   Main Bearing Width   H22A4 = .784   H22A = .784   H23A = .784   H23A1 = .784   F22A1 = .784   F22A4= .784   F23A1 = .784   F23A4 = .784   F23A5 = .784   F20B = .784
   Rod Bearing Width   H22A4 = .762   H22A = .762   H23A = .762   H23A1 = .762   F22A1 = .762   F22A4 = .762   F23A1 = .609   F23A4 = .609   F23A5 = .609   F20B = .762
   Ресурси:   http://www.preludepower.com/forums/showthread.php?t=326846   http://en.wikipedia.org/wiki/Honda_H_Engine
   Имам много информация за допълване, моля допълвайте на воля
 Редактирано от ggushterov - Събота, 23.11.2013, 07:08:30  |
