ABS от 5 генерация в 4
| batkosio | Дата: Петък, 07.03.2014, 22:37:02 | Message # 1 |
| http://www.ludegeneration.co.uk/profile....10.html
5g ABS has much faster response than 4g. 4g ABS is knocking slow and shaking the body when hard braking but 5g ABS is humming and adjust wheel lock much higher frequency thus car handling and braking is way better. 5g ABS modulates all four wheels independently unlike the 4g ABS which does the rear wheels together. 5g ABS is about 20lbs lighter and no need of extra brake fluid. 4g ABS has a PCV (proportioning control valve) for rear brakes which reduces the pressure when hard breaking to prevent locking. 5g ABS doesn't have this, the rear brake pressure is always the same as front so the front of the car does not tilt down so much. (but eating up the rear pads much faster!)
What you need is the following: - 5g modulator unit - 5g ABS control unit (all units support 4WS) - 5g connectors for modulator and control unit - soldering gun, heat shrink tubes, special tools to remove pins from connectors, etc... - tools for metal works, paint, etc... - tools for replacing brake pipe nut
All other things are original 4g: - wheel sensors - ABS main relay (only one needed) - wiring - ABS motor relay - fuses (values must be changed) - brake lines - ABS indicator (need to apply the 5g inverting electronics in the gauge)
Редактирано от batkosio - Петък, 07.03.2014, 22:38:16 |
| ZAPPA | Дата: Събота, 08.03.2014, 00:22:56 | Message # 2 |
| rollin | Дата: Събота, 08.03.2014, 16:34:13 | Message # 3 |
| Аз вече си набавих помпа и компютър
| eDaniel | Дата: Неделя, 09.03.2014, 00:15:35 | Message # 4 |
| Ако на някой му трябват ел.диаграми може да види в секцията Файлове или директно тук: http://preludebg.com/Uploade....nua.pdf
Качих го днес това - беше на близо 500 отделни файла.
| mom4i74 | Дата: Неделя, 09.03.2014, 01:33:08 | Message # 5 |
| Quote eDaniel (  ) Качих го днес това - беше на близо 500 отделни файла. Дани поздравления за положения труд, страхотно е че си го качил но неможе ли да си теглят RAR файла и да си го свалят? Така неработят контролите PHOTO и VIEW от схемата.
| galev_90 | Дата: Понеделник, 10.03.2014, 23:44:54 | Message # 6 |
Съобщения: 592
| Имам въпрос, някой слагал ли е АБС на прелюд 4.Понеже аз нямам такава екстра, ме интересува може ли да се направи и като цяло дали си струва
| VIPER-CH | Дата: Понеделник, 10.03.2014, 23:56:03 | Message # 7 |
| Май ще е по-лесно да си купиш прелюд с АБС Главини,карета,сензори,инсталация,помпа,електроника,табло.....пропуснал ли съм нещо?Със сигурност....
| galev_90 | Дата: Вторник, 11.03.2014, 00:01:13 | Message # 8 |
Съобщения: 592
| Така си и мислех, няма смисъл да се вкарвам в тоя филм.Благодаря
